1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: using the EPICS build system with an IDE
To: "Hill, Jeff" <[email protected]>, Andrew Johnson <[email protected]>
Cc: "Tech Talk \([email protected]\)" <[email protected]>
Date: Tue, 14 May 2013 19:25:17 -0700
I would consider adding a build configuration parameter in the 3.15 version so
this could be enabled by those who want it, but I wouldn't want it to be the
default, which I think you suggested would be acceptable.
Could this be controlled by an environment variable?
Many sites probably have a mix of IDE and cmd line users like we do.
- Bruce
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
using the EPICS build system with an IDE Hill, Jeff
RE: using the EPICS build system with an IDE Hill, Jeff
Re: using the EPICS build system with an IDE Andrew Johnson
Prev: RE: using the EPICS build system with an IDE Hill, Jeff
Next: Re: Relative time in XY graph Himanshu Tyagi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Regarding database links Himanshu Tyagi
