Hi Himanshu.
Yes, you can do this CSS BOY using a script. Firstly, you put a local pv for X PV. In the script, you can write whatever value you want to this local PV and stop writing after 5 for example. Then you can configure the trace to update on X PV only.
Xihui
Sent: Wednesday, May 15, 2013 4:58 AM
To: Fabian S.; [email protected]
Subject: Re: Relative time in XY graph
can we do this in control system studio also?
i have another question from where does the waveform PV gets its time for plotting in XY graph?
i am plotting a PV of waveform type record but I am somehow getting the wrong time displayed in graph.
please suggest
On Wed, May 15, 2013 at 12:10 AM, Fabian S. <[email protected]<mailto:[email protected]>> wrote:
at least in EDM there is a TriggerPV somewhere in the grap settings that
should do what you describe. Down side is that your graph gets updated
even if the value hasn't changed.
The trigger pv could be a calc which gets updated every 1 second and
counts up to 5 where an additonal condition stops the counter/trigger-value.
On 05/14/2013 08:56 AM, Himanshu Tyagi wrote:
> Hi,
> I m new to epics framework. We have a requirement for getting the relative
> time in XY graph so that the all the signals start and stop at same time
> value.
> Is there any way we can control the time values in XY graph and
> have relative scale ,i.e. time should start from t=0 to t=5 sec and then
> graph should stop.
> Regards,
> Himanshu
Himanshu Tyagi
Software Engineer Trainee
fiserv
Pune
P Please consider the environment before printing this e-mail
- Relative time in XY graph Himanshu Tyagi
- Re: Relative time in XY graph Himanshu Tyagi
Re: mmio in epics base Andrew Johnson
Re: Modbus TCP and Omega S. Banerian
<2013>
2025
2026
Re: Relative time in XY graph Bruce Hill
<2013>
2025
2026
