1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streamdevice
Date: Wed, 22 May 2013 08:01:21 -0700
Or he may mean channels within a device or module, such as channels within an oscilloscope or multichannel digitizer. In such cases, the method should be documented by the vendor of the device. There is no generic method or streamDevice-specific method for performing such selections. A couple of things may be worth noting. In some cases, there is a specific SCPI command that effectively says 'for all subsequent commands, use channel n'. Where you are monitoring more than one channel on a periodic schedule, you can put that command into a single streamDevice protocol that may contain other commands that relate to that specific channel. You would probably do so for a number of protocols where you want to address specific channels. Moreover, a single protocol may be contrived that will work for all channels, where the channel number (or other identifier) is a macro variable (like \$1) that is passed to the protocol. The channel identifier might also be a PV such as an analog record or a multibit binary record, and this can be referenced an decoded in the protocol.
If Sebastian has a different meaning for the question, he should rephrase and expand on his intention.
   ---   rod.
On 05/22/2013 07:18 AM, Mark Rivers wrote:
I think he probably means the asyn "addr" field, used to select a specific address or channel of a device.
From: [email protected] [[email protected]] on behalf of Dirk Zimoch [[email protected]]
Sent: Wednesday, May 22, 2013 4:24 AM
To: [email protected]
On 21.05.2013 18:45, Sebastian Matkovich wrote:
is it possible that you cannot access specific channels of a device
through streamdevice? or does somebody know how to do that?
What do you mean with "specific channels of a device"?
Dirk
Re: streamdevice Sebastian Matkovich
Re: streamdevice Dirk Zimoch
RE: streamdevice Mark Rivers
Prev: RE: streamdevice Mark Rivers
Next: Device support for Copley Controls Accelnet Panel Phillip Sorensen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: streamdevice Sebastian Matkovich
