Hi Mark,
We did use the .STUP field on the MAXv with "Model 1" two years ago. I
will test the newer drivers you mentioned.
Thank you!
Mi Qingru
-----原始邮件-----
Sent: Wednesday, May 29, 2013 8:39 PM
To: Mi Qingru ; tech-talk epics
Subject: RE: Status update during no motor in motion
Hi Mi Qingru,
The motor record has a field called .STUP, If you write a 1 to that field it
will update the motor status. This works with any motor driver. So you
could configure a bo record with SCAN=1 second that writes to the .STUP
field for example.
For the older "Model 1" motor drivers, which have separate device and driver
files for each controller type, this is the only way to do it.
For the newer "Model 2" and "Model 3" drivers you can also configure the
driver to periodically do callbacks to the motor record. There are two
configurable callback rates: a fast one when any axis on the controller is
moving, and a slow one when all axes are idle. For these drivers you do not
need to write to the .STUP field.
The MAXv has both an old Model 1 driver and a new Model 3 driver. You can
chose which you want to use. I think the PI C863 only has a Model 1 driver,
but I'm not sure.
Sent: Wednesday, May 29, 2013 1:27 AM
To: Mark Rivers; tech-talk epics
Subject: Re: Status update during no motor in motion
MAXv and PI C863 all need this function. Now we apply motor R6-7.
Mi Qingru
-----原始邮件-----
Sent: Wednesday, May 29, 2013 11:22 AM
You need to tell us what motor driver you are using. OMS58, MAXv, Newport
XPS, etc. And what version of the motor module?
behalf of Mi Qingru [[email protected]]
Sent: Tuesday, May 28, 2013 10:18 PM
To: tech-talk epics
Subject: Status update during no motor in motion
Hi all,
I need to update motor status and position periodically as it has no
motion. If can I only change the wait_time from 1000s to other period such
as 5s in motor_task ?
Mi Qingru
SSRF
- Status update during no motor in motion Mi Qingru
- RE: Status update during no motor in motion Mark Rivers
- Re: Status update during no motor in motion Mi Qingru
Re: Gauge controller with R232 serial port Vahe Sahakyan
PI C863's direction status can't change in time as leaving the limit switch Mi Qingru
<2013>
2025
2026
autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
<2013>
2025
2026
