1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: medm/motif compilation on Fedora 16+
To: [email protected]
Date: Thu, 6 Jun 2013 10:09:06 -0500
MEDM can be built against Lesstif, but I would still recommend OpenMotif if
you can get & use that; see http://motif.ics.com/motif/downloads which has
many packages, or http://sourceforge.net/projects/motif/files/ for a
selection.  There are bugs in the Lesstif implementation so robustness and/or
reliability may be more of an issue there.
- Andrew
On 2013-06-06 Jack wrote:
> On CentOS (redhat rebuild) I'm using lesstiff,
> Hope this helps,
> -Mauro
> ~~~~~~~~~ Mauro Giacchini
> Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
> V.le dell'Universita', 2
> 35020 LEGNARO (PD) - ITALY
> Tel./Fax. +39.049.8068558
> EPICS _at_ LNL http://www.lnl.infn.it/~epics/
> On 6/6/2013 2:06 AM, Emmanuel Mayssat wrote:
> > I have 100's of medm displays.
> > Although I am moving towards Qt, I still need to display my adl files.
> > Can medm be compiled lesstif?
> > A few years ago, it wasn't.
> > If not, is installing  open-motif from source the best solution?
> > (Platform Fedora 16+)
> > Emmanuel
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
medm/motif compilation on Fedora 16+ Emmanuel Mayssat
Re: medm/motif compilation on Fedora 16+ Jack
Prev: RE: asynDriver R4-21: a possible patch for asynRecord.c: test on GigE camera Feng, Kate
Next: RE: max length char for an ENUM michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: medm/motif compilation on Fedora 16+ Jack
Next: Target ARM's iocshell has no command history Amien TLABS
