1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Changing SCAN field in many records
To: Hinko Kočevar <[email protected]>
Cc: [email protected]
Date: Fri, 7 Jun 2013 09:17:57 -0500 (CDT)
Hi Hinko,
I would do this with a seq record.
Tim
----- Original Message -----
> From: "Hinko Kočevar" <[email protected]>
> To: [email protected]
> Sent: Friday, June 7, 2013 1:56:12 AM
> Subject: Changing SCAN field in many records
> Hi,
> We would like to set a SCAN field on several lower level BO records,
> at
> the same time, and the value of these SCAN fields should reflect the
> value of the single higher level record SCAN field.
> For the control of these lower level SCAN fields another, higher
> level
> record, would be used. If a user wishes to set individual lower level
> record SCAN fields, she is allowed. OTOH, when changing the SCAN of
> the
> higher level record, ALL lower lever BO records would get their SCAN
> field set too.
> Is it possible to get this done without using a sequencer?
> TIA and HAND,
> Hinko
Re: Changing SCAN field in many records Hinko Kočevar
Prev: Re: Changing SCAN field in many records Ralph Lange
Next: RE: IP330 modules question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Changing SCAN field in many records Fabian S.
Next: Re: Changing SCAN field in many records Hinko Kočevar
