1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Adding error msgs to dbAccess.c
To: Techtalk <[email protected]>
Date: Fri, 7 Jun 2013 20:11:47 -0700
We recently had an issue where an IOC that had been
working for over a year stopped working.   On investigation,
we found that one of the PV's was in a LINK INVALID state.
We finally traced that to dbAccess.c, and from there to a
gateway configuration issue in which a missing hostname
made a PV read-only that the IOC needed to write to.
I've created a small patch for 3.14.12 dbAccess.c that adds calls
to recGblRecordError where recGblSetSevr is being called
to set LINK INVALID due to a CA put error, along with a
couple of other places where SEVR is set w/o any error msg.
This would have saved us long hours of debugging if it
had been in place earlier, so I thought it might be worth
adding to base.
- Bruce
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
Index: src/db/dbAccess.c
--- src/db/dbAccess.c	(revision 12874)
+++ src/db/dbAccess.c	(revision 12875)
@@ -579,6 +579,7 @@
 		if (precord->stat==SCAN_ALARM) goto all_done;
 		if (precord->lcnt++ !=MAX_LOCK) goto all_done;
 		if (precord->sevr>=INVALID_ALARM) goto all_done;
+		recGblRecordError(status, precord, "Active scan count exceeded!");
 		recGblSetSevr(precord, SCAN_ALARM, INVALID_ALARM);
 		monitor_mask = recGblResetAlarms(precord);
 		monitor_mask |= DBE_VALUE|DBE_LOG;
@@ -886,6 +887,7 @@
         status=dbCaGetLink(plink,dbrType,pbuffer,&stat,&sevr,pnRequest);
         if (status) {
+            recGblRecordError(status, precord, "dbCaGetLink error!");
             recGblSetSevr(precord, LINK_ALARM, INVALID_ALARM);
         } else {
             inherit_severity(pcalink,precord,stat,sevr);
@@ -922,14 +924,18 @@
                 status = dbScanLink(psource, pdest);
-        if (status)
+        if (status) {
+            recGblRecordError(status, psource, "Error processing record via PROC field!");
             recGblSetSevr(psource, LINK_ALARM, INVALID_ALARM);
     } else if (plink->type == CA_LINK) {
         struct dbCommon *psource = plink->value.pv_link.precord;
         status = dbCaPutLink(plink, dbrType, pbuffer, nRequest);
-        if (status < 0)
+        if (status < 0) {
+            recGblRecordError(status, psource, "dbCaPutLink error, unable to write to record!");
     } else {
         cantProceed("dbPutLinkValue: Illegal link type");
RE: Adding error msgs to dbAccess.c Allison, Stephanie
Prev: et_wish installation nalaka samarasinghe
Next: Re: PV name change and autosave Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Adding error msgs to dbAccess.c Allison, Stephanie
