The NDPluginStats does give you SigmaX_RBV, SigmaY_RBV, and SigmaXY_RBV (tilt). These will be the correct sigma values if your beam profile is Gaussian. They are computed by a very efficient algorithm, using the average row and column profiles. It is MUCH more efficient than actually doing Gaussian fitting in 2-D, and can be proven to give the same result. It is fast enough to give real-time results at high-speed.
If you really need N-Dimensions, rather than 2-D, then I don't know of any existing plugin.
From: [email protected] [[email protected]] on behalf of Yingbing Yan [[email protected]]
Sent: Saturday, June 08, 2013 8:49 AM
To: [email protected]
Subject: Is there any plugins or modules for Gaussian fitting?
Hello,
I am using the areaDetector module for the beam profile data
acquisition. The NDPluginStats can be used for basic statistics.
I want to do the Gaussian fitting on the arrays of any dimension. Is
there any plugins or modules?
Best regards,
Yingbing Yan
SSRF
- Is there any plugins or modules for Gaussian fitting? Yingbing Yan
StreamDevice protocol file for Televac MM200 VGC Sinclair, John William
<2013>
2025
2026
<2013>
2025
2026
