1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: configuring RDB archiver from xml files
To: EPICS Tech Talk <[email protected]>
Date: Tue, 18 Jun 2013 10:47:21 -0400
Hello all,
I've run the demo RDB that comes with the RDB archiver and I'm ready to set up an initial engine for testing.  I want to use the xml files from the old channel archiver and I have some questions about the command needed to do this.
The command is: ArchiveConfigTool -engine <engine> -config <config.xml> -import -host localhost -port <port>
Specifically, is that port number the one that the same engine was running on for the old channel archiver, or is it a new port that I need to make available?  For a while at least I want to run the two archivers in parallel, so I need to know whether this port is just used for the import or if it will be used for communication by the RDB archiver.
Thanks all!
James
Prev: RE: EPICS device disconnects and reconnects Mark Rivers
Next: Re: EPICS device disconnects and reconnects J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 转发: Epics ioc share from Phoenix Contact Andrew Johnson
Next: Error message control in StreamDevice Mark Rivers
