1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CSS and Subversion
To: "Kasemir, Kay" <[email protected]>
Date: Wed, 19 Jun 2013 14:47:34 -0400
Kay
Great, thanks. I'm running Windows XP 64 bit, and the Subclipse installation worked out-of-the-box, with no other installations required. For those interested:
 Download site: http://subclipse.tigris.org/update_1.10.x
and I installed the following:
  Subclipse (Required) 1.10.0
  Subversion Client Adapter (Required) 1.10.0
  Subversion JavaHL Native Library Adapter 1.8.0
I remember looking at Subclipse a while ago, and deciding I liked Subversive (from Polarion) better. Subversive is now an official Eclipse project.
Thanks again
Sent: June 19, 2013 2:03 PM
To: Vigder, Mark
Cc: [email protected]
Subject: Re: CSS and Subversion
Hi:
There have been other sites interested in including SVN support, so for a while I tried to include that out of the box in the SNS-supported products, but stopped because we don't really use that here.
As far as I remember, there are several options:
Subclipse from Tigris, subversive from ??.
Again as far as I remember, subclipse "worked", except that it wants you to also have some native SVN tools available on the computer.
So each time you start CSS or Eclipse, it would complain that this piece is missing, which is very annoying if you don't really care to use SVN at all.
If you do use SVN, you'd have those installed, so then it's not a problem.
In short, try subclipse instead of subversive?
Kay
On Jun 19, 2013, at 12:59 PM, "Vigder, Mark" <[email protected]<mailto:[email protected]>> wrote:
Greetings
I'm trying to get the SVN plugin going on CSS, and can't get it working. I've tried installing
the Subversive SVN team provider from the Eclipse Indigo download site (also from the
Helios and Juno sites just in case). After installing SVN, when I try starting CSS, the CSS
application starts up, but in a very crippled state. The Welcome screen has the error message:
       Could not create the view: org.eclipse.ui.internal.ViewIntroAdapterPart
       cannot be cast to org.eclipse.ui.IViewPart
Basically, almost everything is broken. Any tricks to getting this going?
Thanks
CSS and Subversion Vigder, Mark
Re: CSS and Subversion Kasemir, Kay
Prev: Re: CSS and Subversion Kasemir, Kay
Next: Re: EPICS device disconnects and reconnects Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Edm Histogram Carr, Gary
