Hi Nick,
Can you provide some benchmark numbers using the simDetector driver in areaDetector and some standard set of areaDetector plugins? For example:
- simDetector running at 1024x1024 pixels in 8-bit mode
- NDROI plugin configured as XXX
- NDPluginProcess plugin configured as XXX
- NDFileHDF5 plugin configured as XXX
Throughput to disk as a function of which plugins are enabled, etc. would be very helpful. Then I can try to reproduce it and see if the problem can be isolated.
Note that the problem they were having at SLAC dropping with multiple GigE cameras was a function of plugins enabled. But the real problem was the Linux Ethernet driver buffer size, and went away when that was fixed.
There is a brief time window when a plugin takes a lock when frames are queued to it. Some poorly-designed plugins will take the lock for too long, but I think all the ones distributed with areaDetector are OK now.
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Thursday, June 20, 2013 5:54 AM
To: [email protected]
Subject: Using all the cores available on modern processors
This is probably aimed at Mark Rivers (sorry Mark!) but I am hoping other people may have seen the same symptoms. As I mentioned at the last EPICS meeting, on a number of development projects over the past year (mostly with area detector systems, but with some others) we have run into what superficially looks like a common problem.
When we configure a system simply (e.g. an areaDetector configuration which just reads out data and writes it to disk and does nothing else apart from scalar status callbacks) then the main CPU load is on a single core and it can use up to 90% of that core quite happily.
When we make things more complicated and add processing plugins, for example, the data throughput to disk drops off dramatically and frames start buffering up (and some may be dropped). The CPU load is distributed across all cores, but they are only loaded at the 20-30% level, so the system seems largely idle with plenty of processing power available, but it can't be utilised.
Typically we have seen these problems on dual socket NUMA architecture Intel systems, with a non pre-emptively scheduled Windows or Linux OS.
In theorising about this we have conjectured a number of scenarios (in some sort of priority order):
1. AreaDetector has a locking issue and processing is held up by tasks holding locks that they shouldn't have.
2. Because this has happened on non-preemptively scheduled systems, the high priority tasks aren't getting CPU for some reason (despite there being CPU available). This may be related to (1) so maybe the system isn't overcoming priority inversions properly.
3. There is some other resource bottleneck - such as a bottleneck in the QPI because of the NUMA architecture.
4. There is a problem with top or the Windows performance monitor which doesn't account for overheads properly in a busy multi-core system.
So, at this stage we have not looked at this problem in any detail, we have just noticed the symptoms. Has anyone else come across it and have any pointers before we invest a serious amount of effort looking at it. I suspect that if we are going to understand this it may take some time, and may have some design implications for EPICS on modern architectures.
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
- Using all the cores available on modern processors nick.rees
AutoSAVE file cannot use substitution macros Amien TLABS
<2013>
2025
2026
RE: Using all the cores available on modern processors nick.rees
<2013>
2025
2026
