Hello world -
I was wondering if anyone has experience with configuring PCI-PCI bridges for optimum performance (pre-fetching, wait states, etc)? I have an MVME6100 (running vxWorks 5.5.2) with a PMC carrier board (specifically an Emerson/Motorola PMCspan) and a very old VMIC reflective memory PMC board. This configuration has two PCI-PCI bridges between the CPU and the actual PMC board. I am getting *extremely slow* data transfers between the processor and PMC card (reading 320 floats takes 460 microseconds!) . So far I have tried ... with zero success ... - enabling "Fast back-to-back transfers" - ensuring the Pre-fetch memory range on both bridges encompasses the PMC board's address Appended below is the output of pciConfigTopoShow, the PMC card is device [2,2,0]. Any help/hints/references would be appreciated ... Ned iocrtfbdaq> pciConfigTopoShow [0,0,0] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) bar0 in prefetchable 32-bit mem space @ 0x00000000 bar2 in prefetchable 32-bit mem space @ 0x40000000 bar4 in prefetchable 32-bit mem space @ 0xe0800000 [0,0,0] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) bar0 in prefetchable 32-bit mem space @ 0x00000000 bar2 in prefetchable 32-bit mem space @ 0x40000000 bar4 in prefetchable 32-bit mem space @ 0xe0800000 [0,0,1] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) [0,0,2] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) [0,0,3] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) bar0 in 64-bit mem space @ 0xff000000 [0,0,4] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) bar4 in I/O space @ 0x00000000 bar5 in I/O space @ 0x00000000 [0,0,5] type=MEM_CNTLR status=0x0000 ( DEVSEL=0 ) command=0x0000 ( ) [0,0,6] type=MEM_CNTLR status=0x0000 ( DEVSEL=0 ) command=0x0000 ( ) [0,0,7] type=MEM_CNTLR status=0x0000 ( DEVSEL=0 ) command=0x0000 ( ) [0,5,0] type=UNKNOWN (0x80) BRIDGE status=0x0230 ( CAP 66MHZ DEVSEL=1 ) command=0x0006 ( MEM_ENABLE MASTER_ENABLE ) bar0 in 64-bit mem space @ 0xe0000000 [0,6,0] type=P2P BRIDGE to [1,0,0] base/limit: mem= 0xe0100000/0iocrtfbdaq> pciConfigTopoShow [0,0,0] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) bar0 in prefetchable 32-bit mem space @ 0x00000000 bar2 in prefetchable 32-bit mem space @ 0x40000000 bar4 in prefetchable 32-bit mem space @ 0xe0800000 [0,0,0] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) bar0 in prefetchable 32-bit mem space @ 0x00000000 bar2 in prefetchable 32-bit mem space @ 0x40000000 bar4 in prefetchable 32-bit mem space @ 0xe0800000 [0,0,1] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) [0,0,2] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) [0,0,3] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) bar0 in 64-bit mem space @ 0xff000000 [0,0,4] type=MEM_CNTLR status=0x22b0 ( CAP 66MHZ FBTB DEVSEL=1 MSTR_ABORT_RCV ) command=0x0217 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE WI_ENABLE FBTB_ENABLE ) bar4 in I/O space @ 0x00000000 bar5 in I/O space @ 0x00000000 [0,0,5] type=MEM_CNTLR status=0x0000 ( DEVSEL=0 ) command=0x0000 ( ) [0,0,6] type=MEM_CNTLR status=0x0000 ( DEVSEL=0 ) command=0x0000 ( ) [0,0,7] type=MEM_CNTLR status=0x0000 ( DEVSEL=0 ) command=0x0000 ( ) [0,5,0] type=UNKNOWN (0x80) BRIDGE status=0x0230 ( CAP 66MHZ DEVSEL=1 ) command=0x0006 ( MEM_ENABLE MASTER_ENABLE ) bar0 in 64-bit mem space @ 0xe0000000 [0,6,0] type=P2P BRIDGE to [1,0,0] base/limit: mem= 0xe0100000/0xe01fffff preMem=0x00000000e0100000/0x00000000e01fffff I/O= 0xe0900000/0xe00fffff status=0x02b0 ( CAP 66MHZ FBTB DEVSEL=1 ) command=0x0007 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE ) [1,4,0] type=P2P BRIDGE to [2,0,0] base/limit: mem= 0xe0100000/0xe01fffff preMem=0x00000000e0100000/0x00000000e01fffff I/O= 0xe0900000/0xe00fffff status=0x0290 ( CAP FBTB DEVSEL=1 ) command=0x0207 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE FBTB_ENABLE ) [2,2,0] type=NET_CNTLR status=0x0000 ( DEVSEL=0 ) command=0x0082 ( MEM_ENABLE WC_ENABLE ) bar0 in 32-bit mem space @ 0xe0100000 xe01fffff preMem=0x00000000e0100000/0x00000000e01fffff I/O= 0xe0900000/0xe00fffff status=0x02b0 ( CAP 66MHZ FBTB DEVSEL=1 ) command=0x0007 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE ) [1,4,0] type=P2P BRIDGE to [2,0,0] base/limit: mem= 0xe0100000/0xe01fffff preMem=0x00000000e0100000/0x00000000e01fffff I/O= 0xe0900000/0xe00fffff status=0x0290 ( CAP FBTB DEVSEL=1 ) command=0x0207 ( IO_ENABLE MEM_ENABLE MASTER_ENABLE FBTB_ENABLE ) [2,2,0] type=NET_CNTLR status=0x0000 ( DEVSEL=0 ) command=0x0082 ( MEM_ENABLE WC_ENABLE ) bar0 in 32-bit mem space @ 0xe0100000
| ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
