Lets try again *with* the patch file this time...
Hi Benjamin,
On 2013-06-21 Benjamin Franksen wrote:
> Cool. However, for 3.15 I propose to change the existing
> errlogRemoveListener, instead of adding a new function; I was speculating
> on the patch being accepted for 3.14.12.4, which is why I added a new
> function.
I added the ability to delete multiple listeners, and it now returns a count
of the number actually removed.
This version (against 3.15) renames the function and adds a flags argument,
but provides an API-compatible macro for code written against 3.14, plus some
others to give it a simple API.
Comments welcome.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
=== modified file 'src/libCom/error/errlog.c'
--- src/libCom/error/errlog.c 2012-11-09 23:06:32 +0000
+++ src/libCom/error/errlog.c 2013-06-21 21:16:52 +0000
@@ -331,11 +331,12 @@
ellAdd(&pvtData.listenerList,&plistenerNode->node);
epicsMutexUnlock(pvtData.listenerLock);
-epicsShareFunc void epicsShareAPI errlogRemoveListener(
- errlogListener listener)
+epicsShareFunc int epicsShareAPI errlogDeleteListeners(
+ errlogListener listener, errlogDelFlags flags, void *pPrivate)
listenerNode *plistenerNode;
+ int count = 0;
errlogInit(0);
if (!pvtData.atExit)
@@ -343,21 +344,28 @@
plistenerNode = (listenerNode *)ellFirst(&pvtData.listenerList);
while (plistenerNode) {
- if (plistenerNode->listener==listener) {
+ listenerNode *pnext = (listenerNode *)ellNext(&plistenerNode->node);
+ if (plistenerNode->listener == listener &&
+ ((flags & errlogDel_Generic) ||
+ plistenerNode->pPrivate == pPrivate)) {
ellDelete(&pvtData.listenerList, &plistenerNode->node);
- free((void *)plistenerNode);
- break;
+ free(plistenerNode);
+ ++count;
+ if (flags & errlogDel_One)
+ break;
- plistenerNode = (listenerNode *)ellNext(&plistenerNode->node);
+ plistenerNode = pnext;
- if (!plistenerNode) {
+ if ((flags & errlogDel_One) && count == 0) {
fprintf(pvtData.console,
"errlogRemoveListener did not find listener\n");
+ return count;
epicsShareFunc int epicsShareAPI eltc(int yesno)
=== modified file 'src/libCom/error/errlog.h'
--- src/libCom/error/errlog.h 2012-11-09 23:06:32 +0000
+++ src/libCom/error/errlog.h 2013-06-21 21:14:53 +0000
@@ -32,6 +32,19 @@
typedef enum {errlogInfo, errlogMinor, errlogMajor, errlogFatal} errlogSevEnum;
+/* Flags for errlogDeleteListeners */
+typedef enum {
+ /* Define flag bits for internal use */
+ errlogDel_One = 1, /* Remove only the first listener */
+ errlogDel_Generic = 2, /* Ignore the pPrivate value */
+ /* These are the public flag values */
+ errlogDel_All_Specific = 0,
+ errlogDel_One_Specific = errlogDel_One,
+ errlogDel_All_Generic = errlogDel_Generic,
+ errlogDel_One_Generic = errlogDel_One | errlogDel_Generic
+} errlogDelFlags;
#ifdef ERRLOG_INIT
epicsShareDef char * errlogSevEnumString[] = {"info","minor","major","fatal"};
#else
@@ -57,8 +70,16 @@
epicsShareFunc void epicsShareAPI errlogAddListener(
errlogListener listener, void *pPrivate);
- errlogListener listener);
+ errlogListener listener, errlogDelFlags flags, void *pPrivate);
+#define errlogRemoveListener(listener) \
+ errlogDeleteListeners(listener, errlogDel_One_Generic, 0)
+#define errlogRemoveListeners(listener) \
+ errlogDeleteListeners(listener, errlogDel_All_Generic, 0)
+#define errlogRemoveSpecificListener(listener, private) \
+ errlogDeleteListeners(listener, errlogDel_One_Specific, private)
+#define errlogRemoveSpecificListeners(listener, private) \
+ errlogDeleteListeners(listener, errlogDel_All_Specific, private)
epicsShareFunc int epicsShareAPI eltc(int yesno);
epicsShareFunc int errlogSetConsole(FILE *stream);
=== modified file 'src/libCom/test/epicsErrlogTest.c'
--- src/libCom/test/epicsErrlogTest.c 2011-11-14 23:42:50 +0000
+++ src/libCom/test/epicsErrlogTest.c 2013-06-21 20:59:10 +0000
@@ -142,7 +142,7 @@
char msg[256];
clientPvt pvt, pvt2;
- testPlan(29);
+ testPlan(32);
strcpy(msg, truncmsg);
@@ -187,7 +187,8 @@
testOk1(pvt2.count == 1);
/* Removes the first listener, but the second remains */
- errlogRemoveListener(&logClient);
+ testOk(1 == errlogRemoveSpecificListener(&logClient, &pvt),
+ "Removed 1 listener");
pvt2.expect = "Testing3";
pvt2.checkLen = strlen(pvt2.expect);
@@ -198,8 +199,10 @@
testOk1(pvt.count == 2);
testOk1(pvt2.count == 2);
- /* Remove the second listener */
+ /* Add the second listener again, then remove both instances */
+ errlogAddListener(&logClient, &pvt2);
+ testOk(2 == errlogRemoveSpecificListeners(&logClient, &pvt2),
+ "Removed 2 listeners");
errlogPrintfNoConsole("Something different");
errlogFlush();
@@ -314,7 +317,8 @@
testOk1(pvt.count == N+1);
/* Clean up */
+ testOk(1 == errlogRemoveListeners(&logClient),
testLogPrefix();
- Re: Problem in errlogRemoveListener Benjamin Franksen
RE: Using all the cores available on modern processors Mark Rivers
Re: VAL field of PV in ASYN driver Vishnu Patel
<2013>
2025
2026
Re: Problem in errlogRemoveListener Andrew Johnson
<2013>
2025
2026
