Subject: |
Re: caget can't connect to soft ioc on host with multiple NICs |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 26 Jun 2013 17:20:27 -0500 |
Hi Brian,
On 2013-06-26 Brian McAllister wrote:
> The host system has two NICs, one for the facility network and a private
> one for these devices.
> The IOC runs. It connects to the devices and successfully communicates
> with at least one of them.
> However, when I try to use "caget" on the host to access the IOC channels,
> it just times out.
> lsof shows:
> istCoolin 5489 epicsdev 9u IPv4 136863 0t0 TCP *:ca-1 (LISTEN)
> istCoolin 5489 epicsdev 10u IPv4 136864 0t0 UDP
> asym.mit.edu:33586->172.18.0.255:ca-2 istCoolin 5489 epicsdev 11u IPv4
> 136865 0t0 UDP *:ca-1
> I have used soft IOCs before without any such issues but they were in a
> single-network environment.
Do you have EPICS_CA_ADDR_LIST and/or EPICS_CA_AUTO_ADDR_LIST set in the
environment that's running caget? If so, what are they set to?
Usually the problem when running both client and server on a dual-NIC machine
is that you get duplicate replies to the search requests which generates
warning messages from the client library. To avoid that you have to tell the
client to only search one of the networks by setting the above variables.
Maybe that has already been done without your knowledge, but it hasn't been
done quite right?
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: caget can't connect to soft ioc on host with multiple NICs Brian McAllister
- caget can't connect to soft ioc on host with multiple NICs Brian McAllister
RE: caget can't connect to soft ioc on host with multiple NICs Mark Rivers
<2013>
2025
2026
<2013>
2025
2026
