Hi Pete,
I suspect that this delay might be related to CA's orderly shutdown of the winsock (windows socket) library or alternatively related to the CA's orderly shutdown of the TCP socket (the socket can be configured to block until the connection close handshake completes which can be important for example if there is a last CA put message lingering that hasn't been delivered to its destination). Such delays might also be dependent on the exact version of windows. At some point I should probably try to find out what version of windows and watch this in the debugger. FWIW, I don't personally recall seeing such delays (I am using windows 7), but I have been working mostly in Linux, virtualized Linux guest on windows 7, lately.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of D Peter Siddons
> Sent: Thursday, June 27, 2013 8:43 AM
> To: EPICS
> Subject: caget apparent timeout
> Hi all,
> I have a problem which seems to crop up occasionally, depending on
> the setup, but quite often. I have a PC running MEDM screens connected
> to a remote IOC by a crossover ethernet cable. The MEDM apps all run
> fine. Occasionally, I need to check or change a PV, for which I use the
> caget and caput command-line utilities. The operation (put or get) is
> executed immediately, but then the PC waits for several seconds before
> the cursor is returned. Does anyone know what is causing this? It feels
> like a network timeout, but all I have is a PC and an IOC with a
> crossover cable between. Anyone know the fix?
> Pete.
> D. Peter Siddons
> Detector Development Group Leader
> Bldg. 535B
> Photon Sciences Directorate,
> Brookhaven National Laboratory
> Upton, NY 11973
> email: [email protected]
> Phone: (631) 344-2738
- Re: caget apparent timeout D Peter Siddons
- caget apparent timeout D Peter Siddons
<2013>
2025
2026
<2013>
2025
2026
