1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: registerRecordDevice... crashes IOC during startup
Date: Sat, 29 Jun 2013 23:38:13 +0200
Hi Andrew
Am Samstag, 29. Juni 2013, 19:09:40 schrieben Sie:
> I have added some runtime checks to the generated
> registerRecordDeviceDriver routine and to iocInit for a few things such as
> whether TOP is the same, but I don't think it's possible to do what you
> want.
> We don't know at compile-time that you aren't planning to load the xyz
> module from some other .munch file or lib.so shared library (and although
> I don't particularly recommend it, that is something which Dirk Zimoch
> wants to be able to do).
Ok. I understand that. Loading stuff bit by bit at runtime can be very handy.
> Now I could conceive of some kind of optional way
> to test your binary for completeness(which Dirk would not use), but for
> VxWorks that would require that we know all of the symbols that your
> specific VxWorks boot image provides since those are symbols which are
> supposed to be undefined in your .munch file.
Hmm. I see. I wonder why loading a binary that references undefined symbols is
just a warning and not a fatal error, so the startup script would stop at this
point. Or, is there a way to make it one? (This is actually more a VxWorks
question, not much to do with EPICS).
OTOH, I could imagine doing just what you said: checking for all symbols to be
defined by (additionally) scanning the boot image for symbols. I think we have
the tools available, don't we? Do you think it would be possible to hack
something up and (optionally) add it to our build rules?
> That seems like it might be half-way to us creating a fully bootable image
> file containing both the IOC application code and the VxWorks OS, but I
> don't think that would be quite as easy as it might seem because getting
> initialization right (C++ static initializers for our code) could be
> tricky. Has anyone ever tried to do that?
Not me; but isn't that what we do (by default) for RTEMS?
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachm€nts
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: registerRecordDevice... crashes IOC during startup Andrew Johnson
registerRecordDevice... crashes IOC during startup Benjamin Franksen
Prev: Updating the RDB archiver at the STAR experiment L. C. De Silva
Next: Re: registerRecordDevice... crashes IOC during startup Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: registerRecordDevice... crashes IOC during startup Andrew Johnson
