Hi all,
I found some strange build behaviour (on both base-3.14.12.3 using 64 bit CentOs 5.9
and base-3.14.9 using 32 bit CentOs 5.4). If there is a db directory in top's parent
directory that contains a file with the same name as I'm trying to install into
the top's db directory, then the install does not happen.
The following demonstrates this:
cd /tmp
mkdir -p above_top/top
cd above_top/top
makeBaseApp.pl -t ioc Weird
cd WeirdApp/Db/
vi Makefile # uncomment the DB += xxx.db line
touch xxx.db
cd ../.. # back to top
make
ls -l db # the xxx.db file installed as expected - so far so good.
make clean uninstall
# and the weirdness starts here:
mkdir ../db
touch ../db/xxx.db
make
ls -l # no db diretory in top, and no installed xxx.db file.
Is this an intended feature, and if so what is the rationale?
Regards
Andrew Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
SUPPLIERS: As of 1 January 2013, the Australian Synchrotron Company Ltd has changed its business name. However, the trading name will remain Australian Synchrotron.
Please address all quotations and invoices to: Synchrotron Light Source Australia Pty Ltd (SLSA), ABN: 18 159 468 256
- Re: Andrew Johnson
how to use gdb to debug a target IOC? Silver
Which version of Eclipse is required for CSS 3.2.x Xinyu.Wu
<2013>
2025
2026
Re: Andrew Johnson
<2013>
2025
2026
