1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Which version of Eclipse is required for CSS 3.2.x
To: <[email protected]>
Cc: [email protected]
Date: Fri, 5 Jul 2013 11:51:03 +0200
the following Messages of the cs-studio-core mailing list could interest
you:
http://sourceforge.net/mailarchive/message.php?msg_id=31068845 (Building
CSS 3.2.x for Mac OS X)
http://sourceforge.net/mailarchive/message.php?msg_id=30844628 (Eclipse 3.x
(Mac) broken because of Java 7; Eclipse 4 not there, yet)
http://sourceforge.net/mailarchive/message.php?msg_id=30490338 (Eclipse 4
basically required because of Java 7 and Mac OS X)
or generally search the list
http://sourceforge.net/search/?type_of_search=mlists&group_id=285388 for
eclipse...
For Linux (64 bit) I just successfully build CSS 3.2.7 with Eclipse 3.7.2
Indigo using OpenJDK 7.
If you want to build with Kepler then you should use the branch 4.0.x.
-> see http://sourceforge.net/mailarchive/message.php?msg_id=30677967
What is really "needed" I think also depends on what plugins/features from
CSS you add to your product.
The version of the OS is also relevant (because per default it defines your
java version).
Marcus
Von:	<[email protected]>
An:	<[email protected]>,
Datum:	05.07.2013 04:03
Betreff:	Which version of Eclipse is required for CSS 3.2.x
Gesendet von:	[email protected]
We are planning on upgrading our CSS to 3.2.x. Which version of eclipse do
we need? Is it Kepler (4.3)? For both Linux and MacOS?
Xinyu WU
ASKAP Computing
Australia Telescope National Facility
CSIRO Astronomy and Space Science
phone: +61 2 9372 4727
postal: PO Box 76 Epping, NSW. 1710
Which version of Eclipse is required for CSS 3.2.x Xinyu.Wu
Prev: Which version of Eclipse is required for CSS 3.2.x Xinyu.Wu
Next: Macros limited (edition ;-) Touchard Dominique
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
