1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn+streamDevice hangs with synchronousLock:Yes
To: "'Brian McAllister'" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Mon, 8 Jul 2013 19:59:17 +0000
I may try to reproduce the problem using a TCP server that emulates your device.
How quickly is it sending the unsolicited messages?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Brian McAllister
Sent: Monday, July 08, 2013 2:57 PM
To: Mark Rivers
Cc: 'Dirk Zimoch'; '[email protected]'
Subject: Re: asyn+streamDevice hangs with synchronousLock:Yes
>>> On 7/8/2013 at 17:46:03 -0000, Mark Rivers wrote:
  > - Does this occur in a "stripped down" IOC that is only running this
  > single StreamDevice record and nothing else?  Could it be caused by
  > some other code in your IOC?
The only other non-base module included is modbus support.  I also removed
all other databases and device config.
st.cmd:
< envPaths
cd ${TOP}
epicsEnvSet(IOCSH_PS1,"istCooling> ")
epicsEnvSet("EPICS_IOC_LOG_INET","18.229.0.251")
epicsEnvSet("EPICS_IOC_LOG_PORT","20000")
iocLogInit()
epicsEnvSet("STREAM_PROTOCOL_PATH",".:/home/locus/epicsdev/IOC_runtime/protocols")
dbLoadDatabase "dbd/istCooling.dbd"
istCooling_registerRecordDeviceDriver pdbbase
dbLoadRecords("db/hx86pa.db")
drvAsynIPPortConfigure("HX86PA","172.18.0.13:2000 TCP",0,0,1)
cd ${TOP}/iocBoot/${IOC}
iocInit
- brian
Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Prev: Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Next: Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
