Yes there are definitely 120V outlets to work with. I should have specified this in my original email.
-Andrew
Sent: Thursday, July 11, 2013 7:04 PM
To: Gomella, Andrew (NIH/NHLBI) [F]; Maren Purves
Subject: RE: Simple wireless light controlled through EPICS?
Do the locations where you want to mount the lights have 120V power available. Or will you need to run a wire for that at least?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Gomella, Andrew (NIH/NHLBI) [F]
Sent: Thursday, July 11, 2013 6:03 PM
To: Maren Purves
Cc: [email protected]
Not really, it is an x-ray controller box that is under warranty so I can't open it. Maybe I shouldn't say interlock. it is basically a box with a key sticking out of it. It already has an led in it. The thing is EPICS knows the status of the key so I was hoping to use that..
Sent: Thursday, July 11, 2013 6:57 PM
Subject: Re: Simple wireless light controlled through EPICS?
Wondering: can you power a LED from whatever powers the interlock?
(Maybe 'power' isn't the right word here, 'control' would
probably be better)
Gomella, Andrew (NIH/NHLBI) [F] wrote:
> Yes you are right. I guess I'm trying to find something along the lines of a wireless switch that can be easily integrated with EPICS. This is probably trivial for most, the issue here is I cant really run wires room to room (needs to be somewhat temporary solution) and I have multiple doors that need covering (and little experience with EPICS and hardware engineering)
> If it were one door, to be honest I'd probably just put an old laptop on a table next to it and just have it on our local wifi network reading out the PV value to a fullscreen display...
> Mark's suggestion seems the easiest to implement, but I'm not sure I can run the wires. The less elegant option is for me to purchase something like this http://www.amazon.com/dp/B000G80V28 and press it every time I turn the x-ray on or off.
> Thanks,
> Andrew
> From: Maren Purves [[email protected]]
> Sent: Thursday, July 11, 2013 6:29 PM
> Cc: Mark Rivers; [email protected]
> Maybe I'm off, but IMHO you need a switch (that you plug the light
> into) with a (serial or otherwise) control rather than the light
> being controlled itself?
> Maren
>> The interlock came hardwired into our x-ray controller box. It's value can be read with the asyn stream driver and is a BO variable that reads whether the key is in the armed position or not. I was hoping to use this value to trigger lights on or off. Unfortunately I can't modify anything with the x-ray controller, so I figure there has to be some sort of USB light on the market that runs on serial commands? Or maybe such a specific thing does not exist and requires a micro-controller and some work to make.
>> From: Mark Rivers [[email protected]]
>> Sent: Thursday, July 11, 2013 6:02 PM
>> To: Gomella, Andrew (NIH/NHLBI) [F]; [email protected]
>> How is your interlock done? Simple relays or with a PLC? Our laser interlocks here at APS use inexpensive PLCs, and they directly operate the warning lights outside the enclosure.
>> Mark
>> Sent: Thursday, July 11, 2013 4:57 PM
>> To: [email protected]
>> Subject: Simple wireless light controlled through EPICS?
>> Anyone have any suggestions for a simple way to control a light with EPICS? It does not need to be bright, even a small LED will do. Basically I'm trying to have indicators on several doorways to show the current status of the interlock on our x-ray source (which is already a PV).
>> In the ideal scenario it would be connected to wifi so that ethernet/usb cables do not need to be run everywhere. I was thinking of maybe trying to get the "Belkin WeMo Home Automation Switch" to work with EPICS, it is basically a power plug that connects to WiFi. But it is probably easier to find some USB LEDs and run cables.
>> I know some beamlines at APS have EPICS controlled lights, so wondering if anyone has ideas?
>> Thanks!
>> Andrew
- RE: Simple wireless light controlled through EPICS? Mark Rivers
- Simple wireless light controlled through EPICS? Gomella, Andrew (NIH/NHLBI) [F]
- RE: Simple wireless light controlled through EPICS? Gomella, Andrew (NIH/NHLBI) [F]
- Re: Simple wireless light controlled through EPICS? Maren Purves
<2013>
2025
2026
<2013>
2025
2026
