Hey all,
for the settings of the stop switch mode of a motor driver, we are
using, a 16 bit code is used.
Bit 2 and Bit 3 are coding the polarity of the "left" and "right" stop
switch, respectively.
I'm currently using bo records for each bit and one mbboDirect record to
send all 16 bits at once to the device. As device support the
asynUInt32Digital interface is used with a custom asynPortDriver:
record( mbboDirect, "PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE" ) {
field( DTYP, "asynUInt32Digital" )
field( OUT, "@asynMask($(BUS),14,0x1f3c,1)TMCM142_SAP_U" )
record( bo, "PANDA:$(subsys):MOTOR:$(sector):SAP:LEFTSWITCHPOLARITY" ) {
field( OUT, "PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE.B2 NPP" )
field( ONAM, "active high" )
field( ZNAM, "active low" )
record( bo, "PANDA:$(subsys):MOTOR:$(sector):SAP:RIGHTSWITCHPOLARITY" ) {
field( OUT, "PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE.B3 NPP" )
When I now set "PANDA:$(subsys):MOTOR:$(sector):SAP:RIGHTSWITCHPOLARITY"
to one,
PANDA:$(subsys):MOTOR:$(sector):SAP:SWITCHMODE.VAL is 8.
So far so good.
But the value in asynPortDriver::writeUInt32Digital is 0x20.
Having a closer look to the mbboDirect record shows that SHFT is 2.
Setting it to 0 inside the db-file has no effect.
Any idea why it is set to 2? How can I change this behavior?
The same problem occurs for the mbbiDirect record used to read back the
settings.
Best regards,
Florian
| Dr. Florian Feldbauer |
| Helmholtz-Institut Mainz / |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 45 |
| D-55128 Mainz |
| Office: 01/102 |
| Phone: (+49)6131 / 39-27373 |
- RE: mbbxDirect SHFT field Mark Rivers
single IOC on Linux with two ports Hovanes Egiyan
Re: single IOC on Linux with two ports Andrew Johnson
<2013>
2025
2026
RE: single IOC on Linux with two ports Hill, Jeff
<2013>
2025
2026
