I wrote a tiny C program that prints the time taken to do a usleep in a loop, and that also displays the behaviour, so I guess this has nothing to do with EPICS! I'll get onto red hat and see if they have any ideas...
Tom Cobb
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: 24 July 2013 16:33
> To: Cobb, Tom (DLSLtd,RAL,DIA)
> Cc: [email protected]
> Subject: Re: Odd problems with RHEL6 diskless machines
> Hi Tom,
> On 07/24/2013 09:45 AM, [email protected] wrote:
> > When running an IOC with just devIocStats in it, all of the scan
> > tasks seem to pause for up to 300 seconds (about half of the pauses
> > are between 299 and 301 seconds), then resume. During this time an
> > existing ssh connection to the server will continue to work, but
> > channel access monitors may time out. R3.14.8.2, R3.14.11 and
> > R3.14.12.3 IOCs are all affected. dmesg and /var/log/messages show
> > nothing suspicious, and cat /proc/sys/kernel/random/entropy_avail
> > returns 3968.
> Interesting problem...
> Does this have anything to do with devIocStats and the fact that you're
> presumably running the IOC as a real-time process? I don't know the
> internals of that module running on Linux, but the old VxStats module
> on
> vxWorks has a lowest-priority idle thread that every so often busy-
> waits
> for a specific period of time to measure how much work the CPU does in
> the higher priority threads. I could see a problem if devIocStats is
> trying to use the same technique on Linux because IIRC all real-time
> (SCHED_FIFO) threads still have a higher priority than regular threads,
> and this could cause the effect you're seeing. Why it only seems to
> affect diskless systems is still a bit of a question, but I could think
> up some reasons for that.
> Take a look at the internals of devIocStats, and if it has such an idle
> task try disabling it (it should be asking the OS instead of trying to
> measure it anyway). Alternatively, see if not running the IOC as a
> real-time process stops the problem.
> HTH,
> - Andrew
> Advertising may be described as the science of arresting the human
> intelligence long enough to get money from it. -- Stephen Leacock
- Odd problems with RHEL6 diskless machines tom.cobb
- Re: Odd problems with RHEL6 diskless machines Andrew Johnson
Re: Odd problems with RHEL6 diskless machines Ralph Lange
<2013>
2025
2026
<2013>
2025
2026
