1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: motor record: continuously update limit switches
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 25 Jul 2013 21:12:20 +0000
Hi!
I am dealing with a slightly unconventional motor setup where two limit
switches are used for two motor axes in the following way:
-limit switch 1 acts as the high limit for controller 1 and low limit
for controller 2
-limit switch 2 acts as the low limit for controller 1 and high limit
for controller 2
This means the status of the limit switches of an axis can change even
if its motor is stopped. The motor record does not seem to expected a
behavior like that - at least not with the Parker PC6K device support.
The limits are only updated while the motor is moving.
I tried a caput to the STUP field but that didn't have any effect. Is
there a way to force the motor record to update the status of the
switches? This might also be helpful for simple multi-axis operation
with a single home switch.
Any help is greatly appreciated,
Martin
RE: motor record: continuously update limit switches Mark Rivers
Prev: Re: Simple wireless light controlled through EPICS? Richard Farnsworth
Next: RE: motor record: continuously update limit switches Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Odd problems with RHEL6 diskless machines Ralph Lange
