1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Power over ethernet
To: Emmanuel Mayssat <[email protected]>
Date: Tue, 30 Jul 2013 16:52:48 -0700
Hi Emmanuel,
We've been using POE for webcam's and gigE cameras for
several years now and find it very useful, particularly
at our experimental chambers where we often need to move
cameras around.    Most of these devices are class 2, < 3.8W,
and we power them by adding POE modules to our Foundry
switches.   There's also available POE injectors which can be
added inline if your switch doesn't support POE.
We haven't used POE+, so I have no direct experience, but with
the small gauge of the wires in the ethernet cables you may
need to limit your cable lengths for higher power devices.
- Bruce
On 07/30/2013 04:07 PM, Emmanuel Mayssat wrote:
Hello,
After pushing for it, I was 'authorized' to investigate and test power over ethernet.
PoE is basically 48 V DC / 400 mA over CAT5/6, i.e. for <13Watt devices.
Is anyone of you using PoE? or PoE+ (<25W) ?
If so, any comment?
My long term goal is to have, with a minimum hassle,  embedded linux/EPICS in each of my chassis.
Emmanuel
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
RE: Power over ethernet Boyes, Matthew
Power over ethernet Emmanuel Mayssat
Prev: Power over ethernet Emmanuel Mayssat
Next: RE: Power over ethernet Boyes, Matthew
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
