From the device name this is is a USBTMC device, not a serial port. I've seen similar behavior in older linux kernels, you might have more luck
updating to a more recent kernel.
Guy Jennings
On Aug 2, 2013, at 10:36 AM, Eric Norum <[email protected]> wrote:
> Since you can communicate with the unit using simple shell commands I'm inferring that the unit presents itself as a USB-connected serial port. Standard StreamDevice + ASYN support should work fine.
> On Aug 2, 2013, at 5:42 AM, "Drube, Hardy" <[email protected]> wrote:
>> Dear all,
>> I have some problems to establish a longer lasting connection with a Thorlabs PM100USB Powermeter.
>> It is listed in /dev as usbtmc0 and I can communicate with it through echo –e. But this is only possible for one time. A second time echo –e won’t work. I have to disconnect and reconnect the USB-cable. Then again it will work one time.
>> Could you help me with this problem?
>> Note: This device has two chips, the first one is a XILINX XCR3064XL (AD Converter) and the second a NXP LPC2387FBD100.
>> Best regards,
>> Hardy Drube
> Eric Norum
> [email protected]
- Thorlabs USB Hardare with EPICS Drube, Hardy
- Re: Thorlabs USB Hardare with EPICS Eric Norum
Kohzu SC410 Controller Gomella, Andrew (NIH/NHLBI) [F]
<2013>
2025
2026
Re: Thorlabs USB Hardare with EPICS Sorgenfrei, Florian
<2013>
2025
2026
