1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mca Canberra DSA-2000 HV support
From: "Januszewski, Fabian (IAG)" <[email protected]>
Date: Thu, 8 Aug 2013 01:34:54 +0200
I am trying to set up a Canberra DSA-2000 with EPICS + mca on a linux, x86, 64bits.
EPICS R3.14.12.3
mca R7-4
asyn 4-21
Basic operation is fine, setting up the MCA, acquiring spectra.
I am struggling with access to the integrated HV power supply, and am not sure if this is already supported by mca, so far I can't make it work.
My startup script looks like this:
AIMConfig("AIM1/1", 0x..., 1, 2048, 1, 1, "eth0")
dbLoadRecords("../../mcaApp/Db/mca.db", "P=mcaTest:,M=aim_adc1,DTYP=asynMCA,INP=@asyn(AIM1/1 0),NCHAN=2048")
icbConfig("icbHvps1", 0x..., 0, 2)
dbLoadRecords("../../mcaApp/Db/icb_hvps.db", "P=mcaTest:,HVPS=hvps1,PORT=icbHvps1,LIMIT=1300")
Not sure if the last two lines are correct.
icbShowModules says
NI...:0   9   D#QN   2993780
and
mcaAIMShowModules gives
Module     Type  HW rev.  FW rev.  Owner name      Owner ID       Status      Memory size Free address
NI0...    1       2        7       me     ..:..:..:..:..:..  Reachable     262140      00002000
Errors produced are:
2013/08/08 00:59:50.076 mcaTest:hvps1VOLT_LIM devAsynFloat64 pPvt->result.status=-1, process error
2013/08/08 00:59:50.076 mcaTest:hvps1VOLT_OUT devAsynFloat64 pPvt->result.status=-1, process error
2013/08/08 00:59:50.076 mcaTest:hvps1FRAMP devAsynInt32 process error
2013/08/08 00:59:50.076 mcaTest:hvps1INH_LEVEL devAsynInt32 process error
2013/08/08 00:59:50.076 mcaTest:hvps1LATCH_INH devAsynInt32 process error
2013/08/08 00:59:50.076 mcaTest:hvps1LATCH_OVL devAsynInt32 process error
2013/08/08 00:59:50.076 mcaTest:hvps1RESET devAsynInt32 process error
and then periodically
2013/08/08 00:59:59.576 mcaTest:hvps1INHIBIT devAsynInt32 process read error
2013/08/08 00:59:59.576 mcaTest:hvps1OVERLOAD devAsynInt32 process read error
2013/08/08 00:59:59.576 mcaTest:hvps1STATRBV devAsynInt32 process read error
2013/08/08 00:59:59.576 mcaTest:hvps1BUSY devAsynInt32 process read error
2013/08/08 00:59:59.576 mcaTest:hvps1VOLTRBV devAsynFloat64 process read error
Thanks in advance,
Fabian
RE: mca Canberra DSA-2000 HV support Mark Rivers
Prev: Re: Modbus Zenon Szalata
Next: Re: Wireshark CA plugin Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Wireshark CA plugin Eric Williams
Next: RE: mca Canberra DSA-2000 HV support Mark Rivers
