1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Setting console buad rate
To: Yoram Fisher <[email protected]>
Date: Wed, 14 Aug 2013 12:06:27 -0700
Are you using RTEMS or some other operating system?
Looks like there's no easy mechanism in the EPICS RTEMS support for changing the speed from the BSP default that is set in c/src/lib/libbsp/m68k/uC5282/console/console.c
It might be possible use gdb to change the executable image -- the console speed value is stored at IntUartInfo+8, but that's certainly not very convenient.
On Aug 14, 2013, at 10:11 AM, Yoram Fisher <[email protected]> wrote:
> I am using MCF5282 and the default baud rate to the console is 9600 baud.  I would like to change it to 115200.  Any know how this can be done?
> Thanks
> - Yoram -
> Yoram Fisher
> Senior Systems Engineer
> Sydor Instruments, LLC
> 291 Millstead Way
> Rochester, New York 14624
> Ph: +1.585.278.1168,   Fax: +1.585.278.1169
> Email: [email protected]
> web:  www.sydorinstruments.com
Eric Norum
[email protected]
Setting console buad rate Yoram Fisher
Prev: Re: AW: [asyn] link already open! Andrew Johnson
Next: High density thermal diode monitoring Arnold, Ned D.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Setting console buad rate Yoram Fisher
Next: Persistent storage on Arcturus uC5282 Yoram Fisher
