1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Response Time
To: [email protected]
Date: Mon, 19 Aug 2013 08:41:36 -0500
Yasemin,
streamDevice has a ReplyTimeout which you can increase I have used this before
you could try to set that in your protocol file to 5000 and see if that helps.
If I remember right this timeout is in milliseconds.
Marty
On 08/19/13 08:30, Yasemin Barutçu wrote:
Hello,
I've been trying to connect to my machine by RS232.
I use streamDevice and Asyn Module.
When we send command "*IDN?", we expect to get "THERMO OK" from the machine.
I try the same connection on TCP/IP. I used serial to ethernet converter and
communicated with the machine. No problem occured. But when I eliminated the
converter and directly connected to the PC on RS232 port, I got the following
error when I send the command.
I guess the problem is about response time. How can I configure the response
time? Or if it is not response time problem, how can I fix it?
ERROR:
"2013/08/19 16:23:15.340949 thermoConn IDN: No reply from device within 1000 ms"
Response Time Yasemin Barutçu
Prev: Response Time Yasemin Barutçu
Next: Re: Response Time Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
