1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Response Time
To: 'Yasemin Barutçu' <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 19 Aug 2013 14:34:13 +0000
Please send the entire output when your IOC starts up, including the asyn commands to create the serial port driver and configure the baud rate, etc.
From: [email protected] [mailto:[email protected]] On Behalf Of Yasemin Barutçu
Sent: Monday, August 19, 2013 8:30 AM
To: [email protected]
Subject: Response Time
Hello,
I've been trying to connect to my machine by RS232.
I use streamDevice and Asyn Module.
When we send command "*IDN?", we expect to get "THERMO OK" from the machine.
I try the same connection on TCP/IP. I used serial to ethernet converter and communicated with the machine. No problem occured. But when I eliminated the converter and directly connected to the PC on RS232 port, I got the following error when I send the command.
I guess the problem is about response time. How can I configure the response time? Or if it is not response time problem, how can I fix it?
ERROR:
"2013/08/19 16:23:15.340949 thermoConn IDN: No reply from device within 1000 ms"
Response Time Yasemin Barutçu
Prev: asynPortDriver question Jörn Wüstenfeld
Next: Modbus write register update when locally modified haquin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Response Time Pearson, Matthew R.
Next: RE: Response Time Emmanuel Mayssat
