1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: query ioc/cas for list of channels
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 21 Aug 2013 10:42:15 -0700
On Wed, Aug 21 2013, "J. Lewis Muir" <[email protected]> wrote:
> On 8/21/13 11:13 AM, Jameson Graef Rollins wrote:
>> Hi, folks.  Is there a way to query a channel access server (IOC,
>> portable CAS, etc.) for a list of all records it is serving?  I feel
>> like there should be a way, but I haven't been able to find any way to
>> do this yet.
> Hi, Jamie.
> Have you searched the mailing list archive?  I think the following
> thread would help you:
>   http://www.aps.anl.gov/epics/tech-talk/2012/msg02486.php
Hi, Lewis.  Thanks for the link.  I did a quick scan back through the
list, but it was clearly not sufficient!  This thread wasn't even from
that long ago :(
But it is indeed the same thing I was looking for.  And unfortunately it
sounds like there's good way to query a channel server for a list of its
records.
I must say I'm quite surprised to find out there's no method for doing
this.  It seems like a pretty obviously useful feature.
> Also note the difference between records and PVs.  Your subject field
> refers to channels (i.e. PVs), but your message body is asking for a
> list of records.  The two are different.  For each record, there are
> many possible PV names corresponding to the fields of the record.
Yes, sorry, that was maybe a little sloppy.  But I would settle for
either, actually, since there's obviously a lot of overlap.  The set of
records is just a subset of the set of PVs, and the additional fields in
the full set of PVs is predictable from the set of records.
jamie.
Attachment: pgpTLdtS5_C5F.pgp
Description: PGP signature
Re: query ioc/cas for list of channels Andrew Johnson
RE: query ioc/cas for list of channels Dalesio, Leo
query ioc/cas for list of channels Jameson Graef Rollins
Re: query ioc/cas for list of channels J. Lewis Muir
Prev: RE: Thorlabs USB Hardare with EPICS Mark Rivers
Next: Re: Thorlabs USB Hardare with EPICS Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: query ioc/cas for list of channels J. Lewis Muir
Next: Re: query ioc/cas for list of channels Andrew Johnson
