1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problems compiling Nexus library as DLL on Windows
To: Pete R Jemian <[email protected]>, Jan Ilavsky <[email protected]>, "'Mark Koennecke'" <[email protected]>, "Madden, Timothy J." <[email protected]>, "'[email protected]'" <[email protected]>, "'[email protected]'" <[email protected]>, "'Glowacki, Arthur T.'" <[email protected]>, "Schwarz, Nicholas" <[email protected]>
Date: Thu, 22 Aug 2013 19:56:04 +0000
Folks,
The EPICS areaDetector software has been successfully using the HDF5 library (1.8.7) on Windows since R1-7, about 2 years ago.  However, only the statically linked version of the library was installed, which meant that areaDetector applications needed to be statically linked.
I am now writing a driver that must be dynamically linked, because it uses the Microsoft Common Library Runtime (/clr switch on linker).  So I want to also install and use the dynamic version of the HDF5 library.  I installed the dynamic versions of the required .lib files from HDF5-1.8.7_CMake_x64_shared.zip, from the HDF Web site.
When I try to build the ADApp\nexusSrc directory it compiles fine, but I get these errors it tries to link the DLL.   Does anyone know what I am doing wrong?
J:\epics\devel\areaDetector\ADApp\nexusSrc>make
make -C O.windows-x64-dynamic -f ../Makefile TOP=../../.. T_A=windows-x64-dynamic install
make[1]: Entering directory `J:/epics/devel/areaDetector/ADApp/nexusSrc/O.windows-x64-dynamic'
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref /release   /MACHINE:X64     /implib:NeXus.lib /out:NeXus.dll          napi.obj napi5.obj napiu.obj nxdataset.obj  nxio.obj nxstack.obj nxxml.obj stptok.obj      ..\\..\\..\\lib\\windows-x64-dynamic\\hdf5.lib  ..\\..\\..\\lib\\windows-x64-dynamic\\libszip.lib  ..\\..\\..\\lib\\windows-x64-dynamic\\zlib.lib
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_SHORT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT32_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT8_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT64_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_USHORT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UCHAR_g
napi5.obj : error LNK2001: unresolved external symbol H5P_CLS_DATASET_CREATE_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_SCHAR_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_FLOAT_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT8_g
napi5.obj : error LNK2001: unresolved external symbol H5T_C_S1_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT16_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT16_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT32_g
napi5.obj : error LNK2001: unresolved external symbol H5P_CLS_FILE_ACCESS_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT64_g
napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_DOUBLE_g
NeXus.dll : fatal error LNK1120: 19 unresolved externals
make[1]: *** [NeXus.dll] Error 1120
make[1]: Leaving directory `J:/epics/devel/areaDetector/ADApp/nexusSrc/O.windows-x64-dynamic'
make: *** [install.windows-x64-dynamic] Error 2
Re: Problems compiling Nexus library as DLL on Windows Timothy Madden
RE: Problems compiling Nexus library as DLL on Windows Mark Rivers
Prev: Re: EPICS and MEDM with eclipse Pete Jemian
Next: Re: Problems compiling Nexus library as DLL on Windows Timothy Madden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: streamdevice to find the last match Zhang, Dehong
