1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Hardware simulator
To: "Steiner, Mathias" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 29 Aug 2013 15:10:52 +0200
Hi Mathias,
Thanks for your reply! For simple (serial-based) devices such as power supplies, function generators, etc you can write a "software simulator" (written in Java, Python). One could also use a soft IOC like the one you are using. But my concern is more about complex devices and the whole subsystems (e.g., Ion Source), which you want to simulate as close to real operation as possible. I am wondering if anybody is practicing such "hardware simulation" and if not, whether or not it would be useful in the existing physics facilities.
Pavel Maslov, MS
On Thu, Aug 29, 2013 at 2:40 PM, Steiner, Mathias <[email protected]> wrote:
Pavel,
This may be different than what you're looking for but..
I've found it helpful to have simulated power supplies with which to play before the real things are installed.
I've attached them below on the off-chance that they could be useful to someone.
Four records per PS provide "command set", "readback of set point", "readback of actual current", plus a helper calcout for ramping and noise.
Cheers -Mathias
# simulated power supply records for quadrupole magnets
record(ao, "$(sys)_$(sub):$(psnam)_$(inst):I_CSET")
  field(DESC, "magnet power supply")
  field(EGU,  "A")
  field(PREC, "1")
  field(VAL,  "0.0")
record(calc, "$(sys)_$(sub):$(psnam)_$(inst):I_RSET")
  field(DESC, "simulated p/s set pt")
  field(EGU,  "A")
  field(PREC, "1")
  field(INPA, "$(sys)_$(sub):$(psnam)_$(inst):I_CSET PP NMS")
  field(CALC,  "A")
record(ai, "$(sys)_$(sub):$(psnam)_$(inst):I_RD")
  field(EGU,  "A")
  field(PREC, "1")
  field(VAL,   "0.0")
record(calcout, "$(sys)_$(sub):$(psnam)_$(inst):I_LAG")
  field(DESC, "co mimics ramping ps")
  field(EGU,  "A")
  field(PREC, "4")
  field(INPB, "$(sys)_$(sub):$(psnam)_$(inst):I_RD PP NMS")
  field(C,    "5") # this determines how fast the p/s ramps..
  field(CALC,  "ABS(A-B)>C?B+(A-B)/ABS(A-B)*C:A+RNDM-.5")
#               1234567890123456789B123456789C123456789D  beware the 40char(?) limit
  field(DOPT, "Use CALC")
  field(OUT,   "$(sys)_$(sub):$(psnam)_$(inst):I_RD PP NMS")
  field(SCAN, "1 second")
  field(PINI, "1")
  field(FLNK, "$(sys)_$(sub):$(psnam)_$(inst):I_RSET.PROC")
RE: Hardware simulator Farnsworth, Richard I.
RE: Hardware simulator Emmanuel Mayssat
RE: Hardware simulator Steiner, Mathias
Prev: Re: epicsThread Vikram Bhagat
Next: RE: epicsThread Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Hardware simulator Steiner, Mathias
Next: RE: Hardware simulator Farnsworth, Richard I.
