1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: autosave failure S_rpcLib_RPC_CANTSEND
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Tue, 3 Sep 2013 14:02:34 -0500
Hello Lewis,
You stated earlier; "NFS server is a machine running RHEL 5.9."
Did these S_rpcLib_RPC_CANTSEND problems 1st appear after switching to the RHEL 5.9 NFS server?
What version of NFS is your RHEL 5.9 server running?
What was your NFS server before RHEL 5.9?
We had problems with corrupted saveData *.mda files at 2-ID-D that were
only resolved by upgrading to VxWorks 6.9.  We never found the root cause.
Ron
On 9/3/2013 11:43 AM, J. Lewis Muir wrote:
On 5/30/13 5:32 PM, J. Lewis Muir wrote:
On 5/30/13 3:06 PM, J. Lewis Muir wrote:
Using nfsstat on the NFS server, I can confirm that the IOC NFS client
is using NFSv3.  Yes, if you'd be willing, I would love it if you could
send that image!  I'd like to try that to see if it helps.
Hi, Andrew.
Thanks for the image.  After booting with the new image, I've confirmed
the IOC NFS client is using NFSv2 now.  And 'ls' works.  Now I'll just
wait and see if the RPC problem comes up again.
Hi, Andrew.
Just following up to let you know that I have had no problems since
making this change.
It would be great if the root cause could be tracked down and fixed, or
if there was a way to easily configure whether to use NFSv2 or NFSv3, or
I'd even be fine with always using NFSv2, but I don't know if others
feel the same way.
Lewis
autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Re: autosave failure S_rpcLib_RPC_CANTSEND Andrew Johnson
Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Prev: RE: EhterCAT terminals [SEC=UNOFFICIAL] ronaldo.mercado
Next: Re: Serious issue with JCA / CAJ Matej Sekoranja
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Next: Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
