1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: No reply from device within 1000 ms
To: "'Martin L. Smith'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 5 Sep 2013 14:35:19 +0000
You can see what is happening with the communication with the following commands:
asynSetTraceIOMask serial1 0 2
asynSetTraceMask serial1 0 9
where you would replace serial1 with the name of the asyn port for your serial port.
You can also get a report on the driver with
asynReport 10 serial1
If the hardware setup is the same as with cutecom, then it is probably either the baud rate or the terminators.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Martin L. Smith
Sent: Thursday, September 05, 2013 9:19 AM
To: [email protected]
Subject: Re: No reply from device within 1000 ms
Yasemin,
That typically means that the device is not responding to your command, at least
not within the default timeout of 1000 ms. Are you using the same serial cable
as you did with cutecom and the same comm port parameters?
If you have a serial analyzer that you can put between the device and the cable
that would at least tell you if the device is getting the command.
Marty
On 09/05/13 08:18, Yasemin Barutçu wrote:
> Hello,
> I've been trying to connect to power supply by RS232. When I try the connection
> with cutecom everythings work fine. But after creating an epics application and
> send the "*IDN?" command I get following warning and can't read anything.
> 2013/09/05 16:15:56.265500 serial IDN: No reply from device within 1000 ms
> Thanks,
> Yasemin Barutçu
No reply from device within 1000 ms Yasemin Barutçu
Re: No reply from device within 1000 ms Martin L. Smith
Prev: RE: No reply from device within 1000 ms Mooney, Tim M.
Next: RE: Delay within asyn driver (was: epicsThread) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: No reply from device within 1000 ms Martin L. Smith
Next: RE: No reply from device within 1000 ms Mooney, Tim M.
