1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Use element of waveform as input to ai record
To: Phillip Sorensen <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Mon, 9 Sep 2013 17:28:10 -0400
I put a subArray record between the waveform and the AI. Excerpt of db
below, numerous fields deleted.
grecord(ai,"tc_ibda_u_3_AI") {
        field(DESC,"temperature")
        field(SCAN,"5 second")
        field(DTYP,"Soft Channel")
        field(INP,"tc_temp3063.VAL PP MS")
        field(EGU,"degC")
grecord(subArray,"tc_temp3063") {
        field(FTVL,"FLOAT")
        field(INP,"tc_temp3_WF.VAL NPP MS")
        field(INDX,"63")
-ps
On Mon, Sep 9, 2013 at 5:16 PM, Phillip Sorensen <[email protected]> wrote:
> Hello all,
> Sorry if this is obvious thing I have missed, but I am not finding any
> obvious way to do what I am trying.
> I would like the value of an ai record to be set to the value of an element
> in a waveform, and update when the waveform up dates.
> Thanks,
> Phil Sorensen
> CHESS
Use element of waveform as input to ai record Phillip Sorensen
Prev: Re: Use element of waveform as input to ai record Hartman, Steven M.
Next: RE: Use element of waveform as input to ai record Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Use element of waveform as input to ai record Pearson, Matthew R.
