1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Use element of waveform as input to ai record
To: "Mooney, Tim M." <[email protected]>, Phillip Sorensen <[email protected]>, TechTalk EPICS <[email protected]>
Date: Mon, 9 Sep 2013 15:01:50 -0700
Although using the subArray record is the easiest for the job you just described, if you want to do more complicated processing e.g. extract X values in X records or do some convolution/transformation, etc... a subroutine record may be more appropriate.
Long ago, it was called genSub. Now it is called asub and is included in base.
Cheers,
Emmanuel
> From: [email protected]
> To: [email protected]; [email protected]
> Date: Mon, 9 Sep 2013 21:33:40 +0000
> Hi Phil,
> I think you can do this with the subarray record, taking advantage of the fact that the scalar value
> of an array is the value of its first element. I haven't tried this, because I would in any case do it
> with an acalcout record. To write element 23 of myArray.VAL to myScalar.VAL, whenever myArray
> is posted, I would do this:
> acalc.INAA = "myArray.VAL CP"
> acalc.CALC = "aa[23,23]"
> acalc.OUT = "myScalar.VAL PP"
> Tim
> From: [email protected] [[email protected]] on behalf of Phillip Sorensen [[email protected]]
> Sent: Monday, September 09, 2013 4:16 PM
> To: TechTalk EPICS
> Subject: Use element of waveform as input to ai record
> Hello all,
> Sorry if this is obvious thing I have missed, but I am not finding any
> obvious way to do what I am trying.
> I would like the value of an ai record to be set to the value of an
> element in a waveform, and update when the waveform up dates.
> Thanks,
> Phil Sorensen
> CHESS
Use element of waveform as input to ai record Phillip Sorensen
RE: Use element of waveform as input to ai record Mooney, Tim M.
Prev: RE: Use element of waveform as input to ai record Mooney, Tim M.
Next: race condition with calcout & CA input links? Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
