1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: BiRa Ethernet Power Supply Controllers
To: Rod Nussbaumer <[email protected]>
Cc: epics Techtalk <[email protected]>
Date: Fri, 13 Sep 2013 16:35:02 -0400
On Sep 13, 2013, at 9:27 AM, Rod Nussbaumer <[email protected]> wrote:
> Has anyone used any other alternative system to achieve greater load
> current stability? There is a concern about the ability to tightly
> control load current at very low currents. Does this or any other system
> impact that capability?
Hi Rod--
What are your stability requirements? Are you more sensitive to AC related noise or DC drift? Absolute accuracy or relative stability? At low currents, is the concern for discontinuities at zero crossing for bipolar supplies?
I have implemented slow feedback at the EPICS level for DC drift of power supplies which worked adequately for that use case (long time scales). But for AC related noise, you likely need to do that at the controller hardware level. In a previous lab, we used an external DCCT for regulating undulator power supplies (few e-6 stability requirement) using the output from the DCCT in the controller's feedback circuit.
Steven Hartman
[email protected]
BiRa Ethernet Power Supply Controllers Rod Nussbaumer
RE: BiRa Ethernet Power Supply Controllers Allison, Stephanie
Re: BiRa Ethernet Power Supply Controllers Rod Nussbaumer
Prev: Re: TSEL question Andrew Johnson
Next: ASYN on BeagleBone ARM Amien Crombie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: BiRa Ethernet Power Supply Controllers Rod Nussbaumer
Next: autosave timestamp problem Zhang Yuliang
