1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Newport 8742 motor controller driver
To: "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 17 Sep 2013 18:11:13 +0000
Hi Tim,
I would recommend writing a Model 3 driver.  There are 5 Model 3 drivers in the motor/motorApp/NewportSrc directory already that you can use as examples:
AG_CONEX.cpp
AG_UC.cpp
HXPDriver.cpp
SMC100Driver.cpp
XPSController.cpp, XPSAxis.cpp
Cheers,
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Tuesday, September 17, 2013 12:13 PM
To: [email protected]
Subject: Newport 8742 motor controller driver
Does anyone have an EPICS motor record driver for the Newport 8742 picomotor controllers?
We were going to be using the trusty Newport NewFocus 8752 controllers for our project, which we’d got working nicely with the existing PMNC87xx driver, but sadly when we came to order more of them from Newport we were informed they’ve just been discontinued and are no longer manufactured.
The 8742 replacement uses a more recent command set and so doesn’t work with the 87xx driver.  If nobody’s already done it, we will probably have a go a modifying the existing 87xx driver, although I note this seems to use the older “model 1 “ asyn approach so I wonder if we’d be better off starting something like the Newport SMC100 “Model 3” driver instead? (We’ve never developed an EPICS asyn driver before so not too sure what the best approach would be).
Cheers
Tim Hayton
Central Laser Facility
Rutherford Appleton Lab
Scanned by iCritical.
Newport 8742 motor controller driver tim.hayton
Prev: Newport 8742 motor controller driver tim.hayton
Next: Re: Newport 8742 motor controller driver Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
