Hello Everyone
it appears I made a stupid mistake in one of the patches that led to the
last release (2.1.3) of the sequencer: I was a bit over-zealous with
signalling the get/put semaphores in case of timeout and accidentally
did so even in pvGetComplete and pvPutComplete where this is definitely
wrong (they use epicsEventTryWait, so timeout just means 'not yet
available').
The effect is that sometimes these functions return a wrong result: they
can return TRUE when in fact the callback from CA did not yet arrive,
which is particularly bad with pvGetComplete, since it can mean that if
the pvGetComplete is used in a when clause then in the code block that
follows the result is not yet available.
Also note that in non-safe mode, this can lead to a race condition
between update from the CA callback and access from the program,
possibly corrupting the variable's content. This has always been true
for monitored variables, but not when using asynchronous pvGet.
A fix for this (and the other currently know problems) is in the latest
snapshot
http://tinyurl.com/epics-seq/releases/seq-snapshot-latest.tar.gz
and in the darcs repository.
As a side note, the reason I found this bug in the first place was that
I added a test for a new feature in version 2.2. I added a slightly
adapted version of this test to the 2.1 branch, so something like this
should not happen again ;-)
A new release (2.1.14) will be available soon.
Cheers
Ben
"Make it so they have to reboot after every typo." -- Scott Adams
- Re: Bug in seq-2.1.13 Benjamin Franksen
Re: threading in asyn device support Ralph Lange
Re: threading in asyn device support Andrew Johnson
<2013>
2025
2026
<2013>
2025
2026
