1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: LabView interface to EPICS
To: "Faucett, John A" <[email protected]>, tech-talk <[email protected]>, "[email protected]" <[email protected]>
Cc: Emmanuel Mayssat <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 19 Sep 2013 15:05:26 -0700
John,
Let me see if I understand correctly.
You use a device like the cRIO ( http://www.ni.com/compactrio/ ) that include a FPGA.
That FPGA is running code (VHDL +) generated and downloaded through LabView.
The FPGA is programmed for 2 functions: (1) interface with the hardware (2) run an embedded EPICS IOC.
Once the FPGA is programmed, you can interface with its process variable (PV)  to change (let's say) a digital output.
Is LabVIew only only to configure the FPGA?
Or is LabVIew also used to control the FPGA (I/O), i.e. interact with PVs ?
If that's the case, do you use Labview GUIs that interact with multiple EPICS devices or IOCs?
(That is can labview GUI be used as a replacement for edm/BOY/etc?)
Emmanuel
To: [email protected]
Subject: Re: LabView interface to EPICS
Date: Thu, 19 Sep 2013 21:20:06 +0000
Emmanuel Mayssat wrote:
While investigating high-level framework for EPICS, I came across the following page
http://digital.ni.com/public.nsf/allkb/BEF3C387D96E1A0C86257A3600508278
Is any one using LabView with EPICS?
LANSCE is using this for all future generic analog and binary devices.  We have 45 such production IOCs now (compared to 26 VME-based IOCs).
What are the benefit of such a setup?
Fairly good cost per channel.  We can use very similar setups for most IOCs.  We will convert most Camac and our home-grown RICE systems to these.
What are the drawbacks?
Learning LabVIEW.  Learning FPGA programming.  Dependence on NI.  LabVIEW code is much more monolithic compared to ASCII sources (that is, files for a single application are numerous and not human-readable).
John Faucett
LANSCE
LANL
Correspondence
Re: LabView interface to EPICS Faucett, John A
LabView interface to EPICS Emmanuel Mayssat
Prev: Generating a loadable module for cexp (epics 3.14.12.3) Sue Witherspoon
Next: Re: LabView interface to EPICS Faucett, John A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: LabView interface to EPICS Faucett, John A
