1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: cleaning up at exit and waiting threads
To: EPICS <[email protected]>
Date: Wed, 25 Sep 2013 15:15:06 +0200
Hi folks,
Today I did some tests regarding "clean" shutdown of an IOC and found some unsatisfying results. There seems to be no clean way of destroying events, mutexes, or message queues, because they all cannot be destroyed as long as there are threads waiting on them. At least that is the case on Linux.
Example: One thread is waiting on an event. Whenever it gets signaled, it does some work on hardware.
At exit I have do shutdown the hardware cleanly. After this time no thread must try to use it any more. Also I better don't simply kill the work thread while it is accessing the hardware. (And I probably do not know all the threads involved). So I prefer to terminate while the thread has noting to do, i.e. while it is waiting on the event.
I had expected that when I destroy the queue, all pending threads would wake up and receive an error. This is not the case. Instead I found that destroying the event failed with "Device or resource busy"
The same is true for mutexes as I tested. Also message queues cannot be released like this.
Is this a bug or simply "unsupported"?
Any idea what I can do?
Dirk
Re: cleaning up at exit and waiting threads Eric Norum
Prev: Channel Access in Erlang paper at ICALEPCS 2013 Dennis Nicklaus
Next: Re: cleaning up at exit and waiting threads Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
