1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: lvDCOM (LabVIEW -> EPICS PVs on Windows)
To: <[email protected]>
Date: Thu, 3 Oct 2013 18:46:31 +0000
lvDCOM is an EPICS support module that can export front panel variables from National Instruments LabVIEW software applications as EPICS process variables on computers running the Microsoft Windows operating system. The program allows you to rapidly "EPICS enable" existing LabVIEW applications as it is not necessary to modify Virtual Instrument (VI) internals, so it could be used to conveniently wrap e.g. manufacturer supplied applications. As the program uses DCOM for communication, this (ActiveX) needs to be selected in the "VI Server" options of LabVIEW, but this is the only required change to a VI.
Features of lvDCOM include:
* Able to communicate with either native LabVIEW VIs or compiled LabVIEW applications (.EXE)
* Can (optionally) automatically start and/or stop VIs on IOC startup/shutdown
* Can communicate with remote Windows PCs using standard DCOM authentication or a supplied username + password
* Can handle some additional front panel logic e.g. automatically push a front panel button either before doing a read from, of after doing a write to, another front panel variable
For more information on lvDCOM see http://epics.isis.stfc.ac.uk/
Freddie Akeroyd
Scanned by iCritical.
RE: lvDCOM (LabVIEW -> EPICS PVs on Windows) Emmanuel Mayssat
Prev: Re: Sending alarm warnings via email and text L. C. De Silva
Next: RE: lvDCOM (LabVIEW -> EPICS PVs on Windows) Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
