I'm trying to debug a task suspend in our EPICS gateway and
I'm seeing the same pattern in nearly every case. It doesn't
happen
immediately, but seems to possibly be related to some of our IOC's
being rebooted.
First we get gdd reference count underflow errors in the log,
and a "No conversion between src & dest types" error from
casStrmClient.cc,
followed soon by a failed assert in smartGDDPointer.h that calls
epicsThreadSuspend().
Looking at casStrmClient.cc, I found what looks like a missing
unreference
call on a gdd pointer, but why would that cause a reference count
underflow?
Has anyone else seen this problem or have any suggestions?
Thanks!
- Bruce
See below for diff, log file, and stack trace:
Here's where I think we're missing an unreference call in the
3.14.12.3 file:
--- src/cas/generic/casStrmClient.cc (revision 13948)
+++ src/cas/generic/casStrmClient.cc (working copy)
@@ -926,6 +926,8 @@
int cacStatus = caNetConvert (
msg.m_dataType, pPayload, pPayload, true,
msg.m_count );
if ( cacStatus != ECA_NORMAL ) {
+ // bh - looks like we need an unreference here
+ pDBRDD->unreference ();
return this->sendErrWithEpicsStatus (
guard, & msg, chan.getCID(),
S_cas_internal, cacStatus );
The gateway log file looks like this:
#### LOG FILE #####################################
13_20:41:18:CAC: Undecipherable TCP message ( bad response type 8257
) from ioc-las-srv06.pcdsn:5064
13_20:41:18:Oct 13 20:41:18 Warning: Virtual circuit disconnect
Oct 13 20:41:18 !!! Errlog message received (message is above)
13_22:07:10:gdd reference count underflow!!
13_22:07:10:filename="../../../../src/cas/generic/casStrmClient.cc"
line number=895
No conversion between src & dest types no conversion between
event app type=0 and DBR type=20 Element count=1
Oct 13 22:07:10 !!! Errlog message received (message is above)
A call to 'assert(! status)'
by thread '_main_' failed in
../../../../include/smartGDDPointer.h line 106.
EPICS Release EPICS R3.14.12.3-0.1.0 $Date: Mon 2012-12-17 14:11:47
-0600$.
Local time is 2013-10-13 22:07:10.662222000 PDT
13_22:07:10:
Please E-mail this message to the author or to [email protected]
#### STACK TRACE ################################################
(gdb) bt
#0 0x0000003c7680aee9 in pthread_cond_wait@@GLIBC_2.3.2
() from /lib64/libpthread.so.0
#1 0x00002b2756c40b31 in condWait (pevent=0x13b0d230) at
../../../src/libCom/osi/os/posix/osdEvent.c:75
#2 epicsEventWait (pevent=0x13b0d230) at
../../../src/libCom/osi/os/posix/osdEvent.c:137
#3 0x00002b2756c3f66b in epicsThreadSuspendSelf () at
../../../src/libCom/osi/os/posix/osdThread.c:568
#4 0x00002b2756c3d7aa in epicsAssert (pFile=<value optimized
out>, line=106, pExp=0x2b27567ea4ef "! status",
pAuthorName=0x2b2756c4e517 "the author")
at ../../../src/libCom/osi/os/default/osdAssert.c:51
#5 0x00002b27567dfa4c in ~smartGDDPointerTemplate (this=0x14111270,
__in_chrg=<value optimized out>) at
../../../../include/smartGDDPointer.h:106
#6 casMonEvent::~casMonEvent (this=0x14111270, __in_chrg=<value
optimized out>) at ../../../../src/cas/generic/casMonEvent.cc:50
#7 0x00002b27567ddc5c in casEventSys::casMonEventDestroy
(this=0x13c4c628, ev=..., guard=...) at
../../../../src/cas/generic/casEventSys.cc:379
#8 0x00002b27567df16f in casMonEventDestroy (this=0x2aaab070d9f8,
client=..., ev=..., value=<value optimized out>,
clientGuard=..., evGuard=...)
at ../../../../src/cas/generic/casCoreClient.h:247
#9 casMonitor::executeEvent (this=0x2aaab070d9f8, client=...,
ev=..., value=<value optimized out>, clientGuard=...,
evGuard=...) at ../../../../src/cas/gen
#10 0x00002b27567ddd69 in casEventSys::process (this=0x13c4c628,
casClientGuard=...) at
../../../../src/cas/generic/casEventSys.cc:135
#11 0x00002b27567e5179 in eventSysProcess (this=0x13c4c848) at
../../../../src/cas/generic/casCoreClient.h:178
#12 casStreamEvWakeup::expire (this=0x13c4c848) at
../../../../src/cas/generic/st/casStreamOS.cc:151
#13 0x00002b2756c466b2 in timerQueue::process (this=0x13b37538,
currentTime=...) at ../../../src/libCom/timer/timerQueue.cpp:140
#14 0x00002b2756c2ca6b in fdManager::process (this=0x636640,
delay=0.01) at ../../../src/libCom/fdmgr/fdManager.cpp:105
#15 0x000000000041ac86 in gateServer::mainLoop (this=0x13b38c30) at
../gateServer.cc:276
#16 0x000000000040751a in startEverything (prefix=0x7fff1cbbc437
"NET:CAG:LAS") at ../gateway.cc:657
#17 0x0000000000409ab0 in main (argc=11, argv=0x7fff1cbbb118) at
../gateway.cc:1300
Re: VXI11 - GPIB Zenon Szalata
Problem as loading munch to vxWorks/mvme5500 Mi Qingru
<2013>
2025
2026
<2013>
2025
2026
ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
