Hi all, I'm suffering from a problem with a unique setup that I have not used previously.caRepeater is running on serv01. On the GUI machine I setup the following export EPICS_CA_ADDR_LIST="serv01" export EPICS_CA_AUTO_ADDR_LIST=NO If I only run IOC-01 and run the GUI it connects to the IOC-01 records fine. If I only run IOC-02 and run the GUI it connects to the IOC-02 records fine. If I run IOC-01 and then IOC-02 and then run the GUI it only connects to the IOC-02 records. If I then stop IOC-02 the GUI can then connect to IOC-01 records. If I run the GUI first, then start IOC-01 it connects to IOC-01 records. If I then run up IOC-02 it connects to IOC-02 records also. However, opening any additional screens can then no longer connect to IOC-01 records. I should just make it clear that the records on IOC-01 and IOC-02 all have different names, there is not a name problem. I hope I have explained this with enough detail, can anyone help me so that the connections to IOC-01 are not lost(?) when running up IOC-02. Kind regards, Alan Greer
| ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
