1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem as loading munch to vxWorks/mvme5500
To: Dirk Zimoch <[email protected]>, <[email protected]>
Date: Thu, 17 Oct 2013 14:31:17 +0800
Hi Dirk,
I rebuilded the vxWorks including C++, and the problem has been resolved.
Thank you very much!
Mi Qingru
-----原始邮件----- From: Dirk Zimoch
Sent: Wednesday, October 16, 2013 5:13 PM
To: [email protected]
On 16.10.2013 10:32, Mi Qingru wrote:
The problem has ocuured during loading munch as apachment showing.
The vxWorks is 5.5. The Linux is Scientist Linux4.4. The base is
3.14.12.3. And the aysn is 4.21 and the motor is 6-7-1.
Mi Qingru
If you need to set sysCplusEnable=1, there is probably something wrong
with your C++ setup. The file usrExtra.c contains:
#if defined (INCLUDE_CPLUS) || defined (INCLUDE_CPLUS_MIN)
BOOL sysCplusEnable = TRUE; /* TRUE = enable C++ support */
#else
BOOL sysCplusEnable = FALSE;
#endif
So if you build vxWorks with C++, the variable should already be 1.
Dirk
Problem as loading munch to vxWorks/mvme5500 Mi Qingru
Re: Problem as loading munch to vxWorks/mvme5500 Dirk Zimoch
Prev: Electronic & Control Systems Engineer Job Postings at W.M. Keck Observatory Jimmy Johnson
Next: Re: asynError IOC message Vikram Bhagat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem as loading munch to vxWorks/mvme5500 Dirk Zimoch
Next: asynError IOC message Vikram Bhagat
