Hello Dirk, epics> 2013/10/21 11:16:51.892 192.168.1.198:9001 write 7I've done what you suggested. But I can't read passive records 2 values. MEASC\r\n 2013/10/21 11:16:51.906 192.168.1.198:9001 read 8 025 026 2013/10/21 11:16:51.914 192.168.1.198:9001 read 8 027 025 2013/10/21 11:16:51.925 192.168.1.198:9001 read 7 025 026 2013/10/21 11:16:52.025445 thermoIPConn M:TEMP1: Timeout after reading 23 bytes "... 026 027 025 025 026" [root@105 ipThermo]# caput M:TEMP1 1 Old : M:TEMP1 0 New : M:TEMP1 1 [root@105 ipThermo]# caget M:TEMP1 M:TEMP1 26 [root@105 ipThermo]# caget M:TEMP2 M:TEMP2 0 [root@105 ipThermo]# caget M:TEMP3 M:TEMP3 0 [root@105 ipThermo]# caget M:TEMP4 M:TEMP4 0 [root@105 ipThermo]# caget M:TEMP5 M:TEMP5 0 [root@105 ipThermo]# caget M:TEMP6 M:TEMP6 0 Yasemin Hello Yasemin On 07.10.2013 10:03, Yasemin Barutçu wrote: There several possibilities to do this. No that does not work. What you wanted to do is:
MEASC{
separator=" ";
out "MEASC";
in "%d";
But then you get an array of 6 values. Maybe you want to have the 6
values in separate records. You can do this using redirected input:
MEASC{
out "MEASC";
in "%d %(\1:TEMP2)d %(\1:TEMP3)d %(\1:TEMP4)d %(\1:TEMP5)d
%(\1:TEMP6)d";
Called from a record like this:
record (ai, "$(P):TEMP1") {
field (DTYP, "stream)
field (INP, "@thermo.proto MEASC($(P)) $(PORT)")
And 5 passive records like this:
record (ai, "$(P):TEMP2") {
record (ai, "$(P):TEMP3") {
record (ai, "$(P):TEMP4") {
record (ai, "$(P):TEMP5") {
Note that the 5 passive records have no "stream" support (in fact they
use "Soft Channel" or if you wish you can use "Raw Soft Channel").
Dirk
| ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
