1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer + streamdevice
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 29 Oct 2013 12:43:11 +0100
On 28.10.2013 22:41, Christoph Burandt wrote:
Hello again,
thank you all, for some first hints.
A bit more detailed information about my setup:
*debian linux (squeeze, amd64)
*EPICS packages installed from the repository at http://epics.nsls2.bnl.gov/debian/ (EPICS 3.14.12.3)
*StreamDevice-2-6 (from psi website)
*Asyn 4-17
The active lines in the RELEASE file are:
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
SNCSEQ=$(EPICS_BASE)/../modules/soft/seq
EPICS_BASE=/usr/lib/epics
ASYN=/usr/local/src/support/asyn/trunk
The SNCSEQ line seems to point to nowhere (path doesn't exist), but it definitively works for the pure sequencer IOC like this. (!??!)
sncExample.dbd contains one line:
registrar(sncExampleRegistrar)
And the dbd file containing the stream device support is as follows:
streamInclude.dbd
include "base.dbd"
include "stream.dbd"
include "asyn.dbd"
registrar(drvAsynIPPortRegisterCommands)
registrar(drvAsynSerialPortRegisterCommands)
As I gather these line here, I realize, streamInclude.dbd is nowhere being referenced explicitly. Does it have some special status?
Greetings,
Christoph
Hi Christoph,
The Debian EPICS packages install under /usr/lib/epics.
So, if your setting of SNCSEQ points to nowhere, you probably have the sequencer installed as part of the epics-synapps-dev package.
If you want to override stuff with locally compiled modules, specify them as usual in the .../configure/RELEASE file, *before* the setting for EPICS_BASE. (Else your application will continue to use the package stuff in /usr/lib/epics. The order of lines in the RELEASE file is kept in the setting of include paths etc.)
If some rules depend on SNCSEQ being set, set it. Either to /usr/lib/epics, or to a locally installed version, or to any string (in which case stuff is found in /usr/lib/epics).
Your application must include all .dbd files and registrar declarations necessary for both the sequencer and streamDevice. It also must link against all libraries for both the sequencer and streamDevice.
streamInclude.dbd is the dbd-include file for the streamDevice sample application. Do not include it. It just shows what the dbd-include of your application should contain to use streamDevice.
Also note that the epics-synapps-dev package contains asyn as well as streamDevice. Unless you have a good reason to use your own locally compiled versions, I would strongly suggest to stick with the packaged versions. Locally compiled versions are by definition not dependency-controlled by the packaging system, so they work around the strongest advantage of using a package manager in the first place. It is easy to create unstable applications by updating locally compiled modules and not completely recompiling and linking all applications that use them.
HTH,
~Ralph
Re: sequencer + streamdevice Christoph Burandt
Prev: RE: Labview EPICS server and client data types. kathryn.baker
Next: merge multiple alarms Tito Körner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: sequencer + streamdevice Emmanuel Mayssat
Next: Re: sequencer + streamdevice Christoph Burandt
