1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Channel access over wireless?
To: Emmanuel Mayssat <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 31 Oct 2013 17:59:09 +0000
Hi Emmanuel,
This was done by one of the companies that commercialized EPICS. Some work was required to get this done. One thing is to use a directory service to serve as a the directory so that you can directly connect to the channel. There were some other changes - but I do not recall them. I can give you a contact that may help. They installed several telemetry systems running EPICS with this modification to Channel Access.
Bob
From: [email protected] [[email protected]] on behalf of Emmanuel Mayssat [[email protected]]
Sent: Thursday, October 31, 2013 1:55 PM
To: [email protected]
Subject: Channel access over wireless?
I am contemplating a project which requires wireless communication.
I would like to have telemetry information on a control station.
The network link specification is: range 1 mile at 250Kbps
Latency could definitely be an issue (measurement needed at this point)
I could potentially have several 250Kpbs links (not sure whether they can be 'trunked' together)
The remote device could run an IOC (I need something like a 'fast' sequencer for sure)
Between local OPI and remote IOC, I can use any communication protocol I want
Classic architecture:
local OPI ---- (CA over wireless) --- remote IOC
is there a way for an OPI to bypass the UDP discovery process and force connection to a specific IP addres/port?
Other possible architectures:
* mirroring of IOC
 local OPI --- (CA)--- local IOC -----(CA over wireless?) ---- remote IOC
How can you mirror an IOC, PV to PV ? (PV names need not be the same)
* 2 processes with duplicate queries
local OPI ---(CA)--- local IOC ----(serial protocol over wireless) ---- controller to remote hardware
The remote IOC is independent from above and need to query the hardware as well
Maybe IPC could help reduce the number of 'real' queries?
* custom development (with Robot OS, aka ROS, or equivalent)
local OPI ---(CA)-- local IOC --- (serial protocol over wireless)--- non IOC software, i.e ROS
Make sense, but learning curve...
Any input?
Emmanuel
Channel access over wireless? Emmanuel Mayssat
Prev: Channel access over wireless? Emmanuel Mayssat
Next: Re: Channel access over wireless? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
