1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to use calc with two PV to set an ao record on device?
To: <[email protected]>, <[email protected]>
Date: Fri, 8 Nov 2013 11:25:28 +0000
I think that what's wrong is that you need to process the calcout record when the input values change by adding a forward link from every relevant input record,  something like
record(ao, "$(S):$(D)_$(C):RefminAmpSet")
	field(FLNK, "$(S):$(D)_$(C):RefminAmpCalc")
or more crudely, based on periodic processing
record(calcout, "$(S):$(D)_$(C):RefminAmpCalc")
	field(SCAN, "1 second")
You also have to use the OUT field of the calcout record to write to your output record (instead of FLNK) like
	field(OUT, "$(S):$(D)_$(C):RefminISet PP")
Also check your OOPT and DOPT as described here
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Calcout#Output_Parameters
e.g. set OOPT to "Every Time" and DOPT to "Use CALC"
Ronaldo
How to use calc with two PV to set an ao record on device? Benoit
Prev: How to use calc with two PV to set an ao record on device? Benoit
Next: RE: How to use calc with two PV to set an ao record on device? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
