1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: autosave failure S_rpcLib_RPC_CANTSEND
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Mon, 11 Nov 2013 10:30:15 -0600
On 11/8/2013 5:46 PM, J. Lewis Muir wrote:
Well, not so fast I guess.  It just happened again on Saturday, this
time using NFSv2 (using the image you sent me).  The error messages on
the console look the same:
=== console ===
save_restore:write_it: fprintf returned -1. [131101-194540]
../save_restore.c(1636): [0x2f0003]=write_it:S_rpcLib_RPC_CANTSEND
save_restore:write_it: fclose('auto_settings.sav') returned -1
../save_restore.c(1751): [0x2f0003]=write_it:S_rpcLib_RPC_CANTSEND
save_restore:write_it: Giving up on this attempt to write 'auto_settings.sav'. [131101-194540]
Any ideas on how to investigate, fix, or work around?
Hello Lewis,
I mentioned this before in the tech-talk thread, but you may have missed it
amongst a barrage of questions.
We had sever problems with both save/restore and corrupted saveData *.mda files
at several 2-ID-D IOC's this summer.  A sampling of error messages,
save_restore:write_save_file: Backup file (/xorApps/epics/synApps_5_6/ioc/2idd/iocBoot/ioc2idd/autosave/auto_settings.savB) bad or not found. Writing a new one.
[130723-124613] myFileCopy: size=32768, chars_printed=15457
save_restore:write_it - unable to open file '/xorApps/epics/synApps_5_6/ioc/2idd/iocBoot/ioc2idd/autosave/auto_settings.savB' [130723-124613] ../save_restore.c(1346): [0x2f0003]=write_it:S_rpcLib_RPC_CANTSEND
---- splice here -----
saveData: ...will retry in 5 seconds
saveData: * saveData: too many retries; abandoning data from scan '2idd:scanH'
saveData: * saveData:proc_scan_cpt(2idd:scan1): can't open data file!!
I tried a number of solutions. Since we were running VxWorks 6.8 when the
problems started I tried switching back to VxWork 5.5.2; still failed.
I switched back to VxWorks 6.8 and tried using NFSv2; still failed.
The problems were resolved (so far) by upgrading to VxWorks 6.9.
We never found the root cause (which I find very annoying).
(I did create a a procedure that provided nearly 100% failure rate for corrupted
*.mda files from saveData. Contact me if you want more info on this.)
Ron
autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Re: autosave failure S_rpcLib_RPC_CANTSEND Andrew Johnson
Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Prev: Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Next: Re: Subscription updates halting? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
